makpacman
- Mar 21, 2023
Two weeks ago I noticed my 2 year old Kapex had a bit of a concave in the fence. My straight edges showed almost 1mm of gap but I figured it'd need warranty work so I just worked around it with shims behind an aux fence until I felt I'd have time to look into it properly and deal with customer service to get it fixed.
One reason I hesitated as long as I did is because the movable fences need an allen key to remove. Once those were off, and I loosened the allens attaching the fence, the main fence basically sprang straight by itself. I still needed to use a square to align it to my blade and then leverage out the center ever so slightly(~ .2mm) with a scap of oak while retightening the two central bolts, but the fence is dead flat now.
Obviously, I'm not thrilled this can happen, but at least I know what to look for and how to fix it if needed.
Has anyone else had this occur? If so, does the fence stay flat once it's tightened down(I'd also also be interested to know if there is a torque spec for the fence bolts), or should I be trying to get a new fence asap?
