Vincent Palermo
- Mar 3, 2018
Héllo everyone! [smile]
I've restored this AT 65 EB Plunge saw recently, did some minor repairs (bolts replaced, alignment etcetera) and ordered the 'table extension' that slides out to the right hand side for angled cuts.
My question might be pretty simple: When I put the saw on the (modified for clarity->) guiderail and extend the rail to keep the saw from tipping over to the right I have a gap underneath the extension which is the height of the guide rail, so the saw does still tip over!
-> IS there an actual solution to this problem?
-> Does this mean my saw is not 'optimally compatible' with the modern rails for 45° cuts?
Can I find a certain material that I could fix underneath the extension to cover the gap? It would then slide over the workpiece, which would also mean, in either case, that I cannot make cuts close to the edge. Might this keep the saw from sliding well & thus be dangerous?
I'd be very happy with any kind of advice!
I've looked for quite some time to find anyone with the same issue but could not find anything on the internet so far.
Kind regards, Vincent
PS: I've attached some images to clarify the issue!
