Attaching a Marble Slab to Island Bench
Stephen B
[size=14pt]What would you use to attach a Marble Slab to an Island Bench?
Is there a mechanical system? Or would you use adhesive silicon? How about PVA?  Are there other products, ways and ideas?
With appreciation for your ideas or comment.
I would and have used silicone, but I am a total cowboy who shouldn't be allowed near nice things.
Does seem to be holding well at our house anyway.
Silicone is the norm for granite/marble countertops so it depends on the installation. Is there an overhang? If not id use silicone also.
Silicone - but make sure its neutral cure. I've heard of acetic cure bleeding through marble, though I've never seen it myself.
Liquid nails makes a specific adhesive for marble and granite - works very well, non staining.
[size=8pt]
[size=13pt]
Thanks, I appreciate your reply.
However that product is unfortunately NADU [not available down under]. Sellys distributes liquid nails in Australia and they are a seperate company from that producing liquid nails in NA.
So it will be silicon: pictures shortly. Other projects on the go at the moment.
[size=8pt][member=37860]stillwaterBR[/member] [member=14551]Linbro[/member]
