I have the Rikon 14" Deluxe and I like the results. You can resaw up to 11" without a riser block (although I haven't found I need more than about 6" since I have owned it). I believe it has a 1 1/2 HP motor; regardless has enough power to resaw. And, generally the price is much less than most other bandsaws of the same type. The guides are possibly harder to set than some others, but that isn't something you are doing everyday anyway. \
I would guess it depends, to some degree, your use of the bandsaw. If you use it everyday in production work, I'd say maybe you would want something heavier duty than the Rikon. However, if you are into woodworking on the side and it isn't your daily job, I'd guess this saw would last a very long time and, as long as you follow accepted methods of setting up the guides, tension, etc. I doubt you would find anything it can't do for you well. At least that has been my experience so far.
