jmbfestool
WarnerConstCo. said:jmbfestool said:WarnerConstCo. said:mastercabman said:Yes they are kind of big,maybe use a few tap-cons WITH glue?WarnerConstCo. said:I would not want to fill tapcon heads.
Contact cement.
It would be even better if every 24" you drilled a 1" hole in the concrete and glued in a plug.
Mark your base board to line up with the plugs and use some glue and GRK trim screws to go through the base board and hit the plugs in the wall.
That should stay forever. All the double bricker's around here are done like that.
????? Man that seems alot of hassle
JMB
Hassle?
How long will it take to drill some holes with a decent rotary hammer drill?
Only take a second to reference the plug locations, glue and then screw the base board up.
Tapcons would take just as long and regular tapcons suck.
If it takes a half day longer to prep, at least I wouldn't have to come back and fix trim that is falling off.
I kinda already answered! I edited my post but didnt press post but then noticed u was already reading the topic so decided to repost it but then u already posted so kinda backwards now but any way!
The hassle is removing the skirting for no reason! Your removing the skirting just to fix wooden plugs for you to fix the skirting to when you can simply just use good decent plastic plugs SDS (hammer drill) through the skirting and so leaving the skirting in place less mess and hassle. I assure you this method the skirting will never fall off.
I get the feeling only UK members use plastic plugs lol
JMB
