Frank Pellow
- Jan 16, 2007
I promised in the thread: http://festoolownersgroup.com/festool-tool-reviews/festool-carvex-420-(both-mains-and-battery-powered)-comparisons/ to test just how far the Carvex 420 could cut with one charge.
During the last week I have run several tests and the results are shown in this table:
[attachimg=#1]
I used two different fully charged 18 volt lithium ion batteries to run each test two times. I averaged the results.
update: I used 2.6 and 3.0 amp batteries, not the new 4.2 amp batteries
Here are a couple of photos taken during the testing:
[attachthumb=#2] [attachthumb=#3]
All tests were run with A speed, pendulum setting 3, the light turned off, no dust collection, no splinter guard, and following straight lines by eye.
Since (by education) I am a mathematician, I hasten to add that this limited number of tests with only two different batteries and using only one saw means that the results can not be regarded as definitive. I do think that the results are approximately what one should expect using the saw.
I may or may not get around to running more tests and, if I do, I will update the table.
[attachimg=#1]
