chrisrosenb
- Sep 1, 2007
I have always made my face frames
Chris Rosenberger said:The last step before assembly is to cut the bead on all of the parts.
John Stevens said:Chris Rosenberger said:The last step before assembly is to cut the bead on all of the parts.
Hi Chris. Beautiful work, thanks for sharing how you did it. Dumb question (I'm full of them)--why do you cut the bead last?
Regards,
John
Chris Rosenberger said:I cut the parts to size, layout the locations of the rails & stiles & mark the mortise locations. (Rick's Domino Self Centering Jig would have made this less time consuming. Maybe I will get one if I decide to do this more often.)
Next I cut the mortises. I do not use any spacer blocks. I just set the domino fence on the wood & plunge the way Brian Sedgeley showed me to do it.
I have tried spacers in the past, but had more problems with alignment than I do going without.
Next I notched the stile & rails, I then cut the miters on the ends. I did all of these with a Kreg Face Frame Jig.
Chris Rosenberger said:DKurzweil said:Chris,
Based on your photo, it looks like you extended the fence on the Kreg jig.
Can you explain how you did this, it is hard to tell by the photo.
Thanks,
Daniel
Below are some more pictures of the fence. The materials used are a piece of 3/4" plywood, a piece of 1/2" plywood, 3/4" wide T track, 1/2" wide self stick measuring tape, 4 - 1/4" T headed bolts & 4 - 1/4" knobs.
I used the piece of 3/4" plywood for the back of the extension. It is held to the back of the jig fence by the 1/4" bolts in the t slots.
The t track is attached to the top of the 3/4" piece of plywood & lined up with the t slot in the top of the fence. The width of the 3/4" piece of plywood is determined by the thickness of the piece of T track being used.
The piece of 1/2" plywood is used for the face of the extension fence. I made it 3 1/2" wide. The self stick measuring tape is stuck to the top of the 1/2" plywood.
2 slots on the device one vertical, one horizontal. first at the extreme points of 45 degrees. saw off excess fret leveling and straight cutter. it can be improved and made with stops and rulers.galwaydude18 said:In the first picture of the jig do you just move the wood along to suit the width of the upright members?
