Kodi Crescent
- Aug 6, 2010
Hi.
I'm a DIY'er about to begin an attic built-in bookshelf project. My only "box" building experience involves building a toy box for my children, and other than the lid slamming down on their hands, it turned out pretty well.
I'd like some feedback regarding my proposed work method. I can talk myself into saying "this method is a great idea!", but I want some other, more objective, more experienced feedback.
The space I'm planning on filling will have 4 bookshelf-type units. The first will be a unit to hold audio components. It will be sized differently than the remaining 3 units. The other 3 units will (hopefully) be identical. These will all be painted when finished.
I'll be building this out of 3/4 baltic birch plywood. I have a proposed work method. Please provide feedback as to whether it would work or not, pitfalls, etc.
- I'll be using a TS 75 on 2 MFT/3's. I plan on stacking 3 sheets of the BB, aligning the edges, and then fastening them somehow for gang cutting. I'm investigating what method to use to fasten them together so that my parts will come out consistently.
I have an 18g finish nailer. I could use it, but then I'd have to deal with hole filling. That may be something I have to deal with.
I'm considering a Cadex pinner to use the slight head pins, but I'm concerned the pins won't hold during these operations.
I could also use double stick tape. I'm concerned that the double stick tape would shear or move, and hence throw the operation off slightly.
I could use plain old clamps, but I'll may need to move the gangs of items between operations, and I'm concerned about losing alignment.
I plan on keeping all the parts ganged together until I begin with shelf hole drilling. I'd appreciate any advice on what fastener to use, and what to avoid for the fasteners.
- I plan on marking out the parts on the boards, full size. There will be some space between each part to allow for waste, squaring, etc. I plan on rough cutting each of the part stacks out to ease moving them. But the parts will remain in the 3 sheet stacks.
- After rough cutting, I'll cut a lengthwise cut into the ganged unit to establish a straight edge to base further squaring operations on. I'll call this the "reference edge".
- I'll set my parallel guide set to the final cut width. Basing the parallel guides off the reference edge, I'll place the parallel guides and rail on the items, clamp the rail, and cut. I should have my final width.
- I'll then place the ganged bunch on my MFT/3, and cross cut one of the ends to square the end.
- I'll then measure my final length, and set a stop on the MFT/3. I'll place the ganged set in place, clamp, and then make my final cross cut to final length.
I figure that if all goes well, I'll have square, matched parts that are interchangeable. It all sounds good in my head. I wanted to run it by all of you who actually have done this to see if this is a good idea, or if I'm missing anything.
So...am I missing anything? How does this method sound to the rest of you?
Any comments or advice would be great! Thanks!
