mino
		panelchat said:I bought a (second!) TS 55 about two months ago and had some oddball trouble doing some very easy cuts. i found that the 55" rail was bowed out at the center by about 1/16". !
The rail you got was clearly faulty. Such a deviation is NOT OK nor normal. Even for a used rail.
Hard to say if it was damaged on transport or slipped through a QA check.
I am pretty sure such a rail would not pass a QA - unless something was missed by someone.
The Festool FS/2 series seem to have a pretty high accuracy standard. All rails I saw were within 0.2 mm (0.01") across the length when stress-free checked against a DIN Class 0 straight edge (deviation
