Greg M
- Jul 13, 2014
I sold my Ridgid miter saw and stand after buying a Kapex. The Kapex has lived on the shop bench since getting it. I got 2 crown stops for it to extend the work surface and I knew I'd need them in the future for cutting crown. At the time I didn't know that the crown stops were practically useless for cutting crown. What was Festool thinking? What good are crown stops if they can't be used with the wings? This also makes the Festool UG cart useless for me. I don't cut crown very often but it's a feature that I do need. Reversing the wings isn't an option that I care about using. Seems the only Festool solution is to use the MFT mini (or UG), crown stops and a full-size MFT/3 on each side to support the material. Fine while on a flat surface but terrible for an uneven surface. While being a more expensive option it is a much more versatile setup (use of the MFTs for other things).
I'm going to have to start taking the Kapex to the job site in a couple of months or so. I've looked at Festool's option for a mobile stand and it just doesn't make much sense to me for the reason above plus I'm not so sure that the wing design is all that durable for anything more than small dimensional wood or trim.
The Best Fence Pro system looks pretty good. It'll be more of a pain transferring the Kapex from shop use to field use then if I used a MFT mini along with wings or a full size MFT but the Best Fence Pro would be much easier to transport, setup and use in the field wether inside a building or on an uneven surface.
I've done some searching but there doesn't seem to be many comments about the Best system since they've come out with version 2. Anyone use version 2 and what did you think about it?
