I just placed an order for a TS 55 REQ from Tool Nut, but I am torn on what guide rail to get with the saw. I currently own a MFT/3 which has the 42" rail attached to it.
My question would give me the most flexibility? Keep in mind my TS 55 replaces a table saw in my shop and I am a hobbiest woodworker mostly building things like built-in cabinets, bookshelves, and tables.
The options I'm exploring:
1. 42" rail on the MFT/3 and upgrade to a 75" rail
2. 42" rail on the MFT/3; keep the standard 55" rail; purchase additional 75" rail (for cross cut 4x8 plywood; connect 75 + 55 for ripping)
3. 42" rail on the MFT/3; upgrade to 75" rail; purchase to something even larger (avoiding having to use the 42" rail off the MFT/3)? -- It seems less likely I would use a 106" rail often enough and would probably need something in between anyway.
Seing as I am a hobbiest in a small shop; I am trying to keep the cost reasonable but given there is no table saw for finish cuts, I want to make sure any workflow can ensure an accurate cut without much hassle.
