Welshdog
- Dec 1, 2010
Howdy,
I want to put four keyholes (I have a bit for this) on the back edge of a shadowbox style shelf that I am building. With the right wall anchors, this will allow the shelf to be mounted flush to the wall. The boards are 3/4" thick so there is plenty of width for the bit. I'm trying to figure out the best way to do this. The Festool plexi Template Routing Aid is too expensive - I'm a hobbyist and this sort of job will be infrequent. I know folks sometimes use two Parallel Edge Guides, but again, $82 for four holes is a bit steep.
I'm trying to set up the MFT with a rail and the router guides and the board clamped to the edge of the table. I have the Table Widener installed on the router. This looks like it should work, but it also seems a bit awkward. Not 100% sure, but I think I see a slight misalignment of the router plate to the top of the board. Pondering this.
Am I missing something here? Is there a better way to put keyholes in board edges?
Thanks!
Thanks!
