Best way to router a slot into the edge of a board using OF1010
joesan
TLDR: Any advice please on the safest, most effective way to router a slot into the edge of a board?
I need to install some T-Bar edging to cover the unfinished edge of some 18mm MFC. Here's a diagram to illustrate things. I'd like guidance on the best way to stabilise my OF1010 to make a safe accurate cut 2mm wide along the length of the edge of the board. This is for some shelves around a meter long.
I'd definitely add the AFB-OF 1010 R that Jeff mentioned...578058.
[attachimg=2]
Thank you folks. I wasn’t aware of that accessory. I’ll take a look and see if it will do the job for me.
I can give a 3rd on the ABF OF and now they are easier to get. Originally, they were only available is a larger kit of accessories, now they are sold sepatately.
Pushing one of those bearing guided slot cutters is about the most trivial thing you could do with a router. Anything from a trimmer to a large router will work just fine, simply keep the pressure down on the side of the router resting on the board and go.
Literally a 10 second job. And if it wobbles a little in use, that's no matter as a strip is being fitted that will take up any slop along the length anyway.
This ^^^^^^^ Absolutely no need for overcomplication or extra gadgets.
Sparktrician said:
I think I'd rather make that cut on a table saw.  (Just sayin'...)  [unsure]
Yes but...
OP needs a 2mm slot. Therefore he needs a table saw blade with a kerf less than 2mm (.787"). OP is in Germany so maybe that's common. The CSC SYS 50 uses 1.8mm kerf blade but I don't know about other saws and blades in Europe.
Agree with the others - use the router and the slot cutting bit.
I agree.  Though I added a home-made router plate to my P-C 690 for this application.  Similar (but not as nice) as this Rockler version.  (I don’t know if it is feasible with the Festool version).
While this is 100% true, some folks are not exactly comfortable with routers.
For me, volume would probably dictate the approach. If I had just one 1m shelf, I'd just hit it quick with one of the Makita cordless trim routers, not concerning myself over a tiny mess.
If I had a bunch of them, I would set up the router table, just for the dust collection.
If the pieces are bigger, bring out the OF1010, again for the extraction. (In a case where the part is large/heavy, and it's easier to bring the tool to the work)
There is no one answer, especially for a pro, who can run into anything.
