Hi all,
I have a 42 x 38 table top and I want to put a beveled edge. I guess I can use a hand plane but I'm wondering if I can use a raised panel bit and a hand-held router. For a small table top, I use my bandsaw to cut a bevel but this one is too large for that. I assume that OF2200 can accommodate a large bit (3.5 inch), but swinging such a bit by hand sounds scary to me. Have any of you done it before? Or you wouldn't recommend it? I want to put a gentle curve on the edges of the table top. So, hand plane could be challenging, if not impossible. If I use my hand plane, maybe I'd better keep the straight edge. Either way, maybe I want to use my Carvex to remove some wastes first, although I may need to buy an angled base to put a bevel angle with it.
Anyway, I would appreciate your thought about it.
Thanks,
Thanks,
