Big Order coming up
Ive got a big order coming up, it looks like it will be over €1000 my last order which had a variety smaller items too  and one big ticket item was up there too, the big item was HKC set that made the total amount more acceptable psychologically..
This next order contains no power tools that sand or cut or drill. The closest thing to a powertool is the Syslite Kal II.
So what makes this order så expensive? Well the Syslite Kal II costing €160, the new Sleeved 3.5mm 22-27mm hose is relatively expensive. I'm going Sortainer shopping as well, so at 96 euro for the Sys 3 Sort 6 makes the total jump  again.. Other than that another battery for the TI impact, somehow they mixed up at my otherwise faultless supplier and sent an 18v 5.2Ah instead of the required 14.4v  5.2Ah i could have them exchange for the proper one, but on second thought I have  5 akku tools with the Carvex HKC, PDC, TI impact, and the Syslite, so another battery so I have 5 18v batteries 2 15v, and the 2 10v 2.6 Ah batteries does not seem to excessive especially if I experience any failures in the middle of a project...
Other than these items I'm getting an extra standard blade for the HKC, the flush piece like a flat parallel guide that improves DC on the HKC, jigsaw blades for the Carvex, a few 100 piece boxes of sand papir for the RS 300 EQ  Rotex 90 DX sanders, I'm also getting som Platin 2 abrasive for the Rotex, to try getting a near polish finish on some painted doors and tables..
A few other extra pieces, the quick clamps, sys carts x2
On another order from a different supplier I'm getting one more Sys 4 Sort three and the Sys Combi 2...
Just a little surprised at how fast a list like this grows... Just have to get to grips with the fact that  I'm getting  consumables and accessories this time and it is costly.. [blink]
The stack from this year is about 3k Euros.
it does not take long.
Well I ordered now. Changed a few things to make room in the budget for the Syslite Duo.
Artikelnummer: 500269
1 x Festool Sleeved hose Plug it-Kabel D27/22x3,5 AS-GQ -- I had been sanding quite a lot of tables lately and the non sleeved hose with the loose plug it kabel got extremely irritating now I hope that issue solved will improve my productivity and make the work more enjoyable to boot.
Artikelnummer: 493047
1 x Festool Connection muffe Antistatik D 50/D 50 VM-AS 493047 so I can join my two hoses together for a 7 meter 27mm hose
Artikelnummer: 452892
1 x Festool Antistatik rotating Muffe D 27 DAG-AS 452892 needed for joining the two hoses. I don't think it will be ideal joining a non sleeved hose with the sleeved hose, but if I need to do it for working up on a ladder I've got the gear to set it up now..
Artikelnummer: 497694
1 x Festool Systainer SYS 1 BOX . I have one sustainer SYS 1 already and it's already filled up, and my hardware assortment is nowhere near complete..
Artikelnummer: 495020
1 x Festool SYS-CART RB-SYS, make moving the Sortainer Stack around the shop much easier..I keep the tools up on shelves..
Artikelnummer: 497855
1 x Festool Festool labels for T-Locs AB-BF Sys TL 55x85mm /10
Artikelnummer: 700357
1 x Festool Insert for SYS TI 15
Artikelnummer: 491750
1 x Festool Fllush plate for the HKC to improve dust collection ABSA-TS 55
Artikelnummer: 491473
1 x Festool anti splinter for the TS-75 SP-TS 55/5 491473
Artikelnummer: 491582
1 x Festool anti kickback stop FS-RSP 491582
Artikelnummer: 487779
1 x Festool TURBOFILTER TF II-ET/RS/5x This is for when I'm out with the RS 300 EG without a vac.. They bags work surprisingly well..
Artikelnummer: 583129
1 x Festool POCKET-STICKFIX STF 46X178  This will be a perfect match with my RS 300 EG abrasives..
Artikelnummer: 497392
1 x Festool Granat 93V  P80 (50 Stück)
Artikelnummer: 497394
1 x Festool Granat 93V  P120 (100 Stück)
Artikelnummer: 497396
1 x Festool Granat 93V  P180 (100 Stück)
Artikelnummer: 492915
1 x Festool Brilliant 2 93x178 mm P120 (100 Stück)
Artikelnummer: 492917
1 x Festool Brilliant 2 93x178 mm  P180 (100 Stück)
Artikelnummer: 492920
1 x Festool Brilliant 2 93x178 mm  P320 (100 Stück)
Artikelnummer: 497369
1 x Festool Granat Ø90mm f P180 (100 Stück)
Artikelnummer: 497404
1 x Festool Vlies Ø90mm zum Anschleifen A80 - S800 S800
Artikelnummer: 498323
1 x Festool Platin 2 Ø90mm Schleifscheiben S500 - S4000 S1000
Artikelnummer: 493836
1 x Festool PREM,-LAMMFELL LF-PREM,-STF-D125/1
Artikelnummer: 488715
1 x Festool SCHLEIFSCHUH SSH-STF-V93/6-W/2 für ROTEX RO 90 und DX 93
Artikelnummer: 488716
1 x Festool SCHLEIFSCHUH SSH-STF-V93/6-H/2 für ROTEX RO 90 und DX 93
Artikelnummer: 4835831
1 x Festool Vlies 93x175 mm  S800
Artikelnummer: 497697
1 x Festool Kompakt-cleaning set D 27/D 36 K-RS-Plus 497697 I'll use the Sys-1 for the TI impact
Artikelnummer: 498411
1 x Festool Selfclean bags SC-FIS-CT MIDI/5
Artikelnummer: 456790
1 x Festool Filter HF-CT MINI/MIDI 456790
Artikelnummer: 4014549223628
1 x FESTOOL Panther for the HKC 55 PW12 # 500460
Artikelnummer: 200164
1 x FESTOOL LED  SYSLITE DUO im Karton IP55 8000lm 180Grad 200164
Artikelnummer: 498324
1 x Festool Platin 2 Ø90mm Schleifscheiben S500 - S4000 S2000
Mostly painting gear and organising gear. I think for my uses the Syslite Duo is more immediately useful then the Syslite Kal II, the price difference wasn't that great, and I'll be using it outdoors in cool conditions sometimes, so battery power is less reliable. Not that I won't end up getting the Kal II at somepoint in the not too distant future..
