- Sep 16, 2014
With my little printer, I was just able to make 4 holes drilling jig. I recently received a Bambu Lab X1C with a build surface of 256mmX256mm and I was able to make 9 holes MFT drilling jig. I'm really happy for the quality but also the speed of that printer. On my first model, I did a forstner drill bit guide but not all forstner bits are created equal so it's not really interesting. By concentrating on only plunge router hole boring, it's a little easier. My question is any of you drilled their MFT top using other boring bit than the Festool one? I see other companies like Amana, Bosch or CMT that sells 20mm boring bit but most of them have 10mm shank. Can I use a 1/2 inch to 10mm collet on a router and use that bit to drill?
I looked at another thread here and the CMT 392.200.11 bit has been recommended (with 8mm shank). Do you have any other one?
Thank you
Thank you
