MikeyBikey007
- Dec 9, 2023
I'm building two small Paulk Smart Benches approximately 2'x4' with MFT-style tops. I'm going to use the Parf MKII system to drill the holes. I stacked, aligned, and screwed the two tops together to drilled all the 3mm holes. It turned out to be a 6 x 12 grid of holes with the 96 mm vertical and horizontal spacing. I'm getting ready to drill the 20mm holes and was wondering if anyone had drilled two tops while still stacked and screwed together. I can see the time efficiency as a real plus but I was wondering if there are any negatives that I might be missing. It looks like the standard UJK 20mm Forstner bit will be long enough. I was going to pre-drill the underside to reduce any blowout. I'll make sure to go slow and clean out the hole to reduce any heat build up. Any other thoughts or concerns from the collective before I start drilling.
