narrowboatboy Member Joined Dec 2, 2011 Messages 60 Apr 3, 2015 #1 TS55 = 55mm depth TS75 = 75mm depth standard building par lumber here is 95mm, so a TS100 please
O Ohc917 Member Joined Oct 5, 2014 Messages 29 Apr 6, 2015 #2 https://www.festool.com/Products/Pages/Product-Detail.aspx?pid=769531&name=Carpentry-circular-saw-HK-132-E
O orm8426 Member Joined Jan 30, 2015 Messages 109 Apr 6, 2015 #3 18KG, 2300W, 350mm blade! Yikes! That's a real man saw. [eek]
S sae Member Joined Aug 13, 2014 Messages 845 Apr 6, 2015 #4 orm8426 said: 18KG, 2300W, 350mm blade! Yikes! That's a real man saw. [eek] Click to expand...
E elfick Member Joined Jun 7, 2013 Messages 681 Apr 6, 2015 #5 When you absolutely, positively, got to cut every two-by-sixer in the room (at the same time), accept no substitutes. [eek]
O orm8426 Member Joined Jan 30, 2015 Messages 109 Apr 6, 2015 #6 elfick said: When you absolutely, positively, got to cut every two-by-sixer in the room (at the same time), accept no substitutes. [eek] Click to expand... Ok, I stand corrected! THAT'S a man saw!! [cool]
T Tyler Ernsberger Member Joined Sep 30, 2014 Messages 895 Apr 6, 2015 #7 Thats a scary saw. Glad I dont have to use it.
Holmz Member Joined Oct 11, 2014 Messages 4,001 May 21, 2015 #9 narrowboatboy said: sadly not available UK [sad] Click to expand... Once you get to the shores of Normandy you can continue on foot... (They also ship out of Germany) I see this and think it needs an expansion chamber on the chip-exhaust [tongue] sae said: ... Click to expand... narrowboatboy said: TS55 = 55mm depth TS75 = 75mm depth standard building par lumber here is 95mm, so a TS100 please Click to expand... They make one that does 125-mm http://www.mafelltoolstore.com/mks-130-ec--13-portable-circular-saw--.html
