So it is my first time using a biscuit joiner. I got it for pre assembling some casings at a job we will be doing tomorrow. I already have the clam clamps which are awesome and I just wanted to be able to reinforce the joint a little more with a biscuit joiner. I searched all the forums yesterday deciding on whether or not to get the domino or a biscuit joiner for pretty thin casings(2 1/4 x 9/16). I decided I'd try out the biscuit first and eventually in the next couple years I hope to get the domino. So I have a couple questions: 1.What size biscuit should I use for this casing?Is there a certain rule you can apply to every size material?(I was thinking the O). 2. I have read some posts about cutting a hair under a 45 degree on the miters so that when you nail up the casing you force the inside miter to lock really tight together. My question is, is this necessary to do if I am biscuiting and clam clamping the miter? Any hints or tips would be great!!! It is all stain grade, so it has to look perfect. Thanks Guys!!!
