Hi All,
Curious about whether this is a problem or to be expected.
I was straightlining some 1.875" thick hard maple this evening. Using my ts55 with a freud 14 tooth blade. Speed set around 2.5
At first, I was trying to plunge cut (I had the stop on the rail). When I did this, I noticed that the blade had trouble going in and would actually stop about half way through the cut. A little disturbing.
After about the third time, I backed off the track far enough that I could plunge the saw all the way down before hitting any material. Doing this, I could then cut through the wood without a lot of struggle. The saw doesn't seem to love it, but it can do it
Is this normal? Should I be concerned or considering bringing the saw in? This only happened once before while installing a Bamboo floor and ripping planks using a melamine blade. Most of the cuts were no problem, but one got bogged down and stopped repeatedly.
Thanks,
Adam
Thanks,
Adam
