The critical dimension is not kerf but the amount of offset between the mounting, or inside, face of the blade and the inside cutting edges. We can assume the teeth are centered on the blade but that doesn't really tell us anything. Are the bodies the same thickness? Theoretically, the kerf on one blade could be twice as thick as another blade and still cut to the splinterguard exactly the same as long as the mounting surface to splinterguard side cutting edges distances are the same. All the difference would show up on the side away from the splinterguard. First chance I get I will set a couple blades up on a plate and check this offset with an indicator.
