I've had the TS 55 FEQ-F US for a few years. Not a lot of hours on it as I am a hobbyist but Ive built a few things.
Background: Sometime in 2023 I dropped it and and for whatever reason I thought it needed adjusting, so I recalibrated it as best I could and figured "good enough" Then just recently (December 2024) I was building a chicken coop and had the saw trigger its kickback feature (I think?) It jolted in my hand and the blade immediately stopped. This was due to not properly securing some 2x4s I was cutting so I think one end pinched the saw as it was cutting. Anyway, I later took the blade off for cleaning and there were minor knicks in the blade body around the arbor hole, which I assume was from the force of the blade stopping. The blade itself was/is flat (at least when laying it on plywood) and there was no damage to any teeth.
So now, I am gearing up to build some furniture (drawers for a previously completed vanity + tool storage / workbench) and figured I should check the calibration and get it dead on 90.
I have been using the method described here:https://www.festoolownersgroup.com/...g-blade-angle-squareness/msg526940/#msg526940 with MDF (2x 1/2" pieces glued up, so ~1" thick) and I just cannot get it to zero gap. In addition, the cut pieces touch in the middle but with a gap on either end...so it seems the cut itself is not completely straight? I thought maybe I needed to support the rail better, but still get the waviness.
I'm thinking of just sending it into Festool to have them check it out and calibrate it, but wanted to get some feedback on what could cause a wavy sort of cut or other things I should check before sending it in?
Toe in is ok I think - I adjusted it and folded paper can get in the back but not the front.
Any help or suggestions are appreciated, thanks
