ChuckS said:
Unless the plaster lines up evenly as a layer on the WHOLE surface of the bag, the 10% vs 99% claim needs further investigation.
Practice rules. I am confident coen has a 10+ projects behind him backing his statements.
Plaster or concrete dust will clog-up the micropores of the bag and Self-Clean will not help as the particles are smaller than its net. This will affect the suction already at the 5-10% full, but is actually completely INDEPENDENT of the bag fullness. If one had 50% full bag from wood work, then put in 10% plaster dust, he would clog it at 60%, not 10% as new one.
Festool SelfClean bags lining is anti-stick and works for particles bigger than a certain size only, those will fall down by gravity when the vac is stopped. Is also why the main filter is horizontally above the tub. The bag fullness, per se, does
not affect the suction performance. That is also why the Festool vacs are so great for cyclone use.
What, I believe, was coen's original point is that anecdotal evidence from a wood-dust-producer is not universally applicable. Reason being that wood dust, including "microdust" from sanding, is actually fairly large
compared to plaster dust particles and thus the anti-stick SelfClean bags can fully show their prowes.
It is no coincidence that Festool was the /only ?/ one to bother with the SelfClean gbags tech - despite it being effective only on "bigger" particles. Most other vac makers do not sell predominantly to woodworkers ... thus the benefts of SelfClean would not be interesting to big parts of their customer base.
Short but concise:
