jaguar36
- Jul 19, 2011
I just installed some drawers that are hidden behind hinged doors. The drawers use Blum Tandem slides, while the doors use Blum compact hinges. I was suprised to find that there is a slight interference between them where the sides of the drawers rub against the adjustment screw of the hinge (see pic). Has anyone run into this before? I’m using 12mm ply for the drawers, and I thought this was a fairly common arrangement so I was suprised to have an issue with it.
My only thoughts to fix it are to either grind down the head of the adjustment screw, or cut a dado in the side of the drawers to clear the screw. Obviously neither of these is ideal.[attachimg=1]
