bobtskutter
bobtskutter said:Is the door catching at it's bottom left corner, see the photo below?
Bob
festal said:Front to back slightly out of level
Vertical sides seem level
Bottom is not
Checked few other cabinets and this one is the one with issues. Others are ok
festal said:This kitchen is over 10 years old so it might be due for remodel at some point. Not sure if it’s worth doing anything to this specially reinstall.
tjbnwi said:The Blum hinge will be 73B3550, this will be a soft close hinge, if you do not want soft close; 73T3550.
Plates are hard to tell from the picture, they will be either 175H7100 0mm or 175H7130 3mm.
The .** Blum plates will not work in this application, the shortest is too tall.
waho6o9 said:Scribe the bottom of the door and be done with it, and or plane or sand to fit.
Packard said:tjbnwi said:The Blum hinge will be 73B3550, this will be a soft close hinge, if you do not want soft close; 73T3550.
Don’t you need to know the overlay? Or maybe all IKEA cabinets have the same overlay?
tjbnwi said:Packard said:tjbnwi said:The Blum hinge will be 73B3550, this will be a soft close hinge, if you do not want soft close; 73T3550.
The hinge I listed will adjust to a 20mm overlay, looking at the picture in post #1 it appears to be 19mm overlay. You can control the overlay with the plates also, thus the 2 part numbers.
festal said:tjbnwi said:Packard said:tjbnwi said:The Blum hinge will be 73B3550, this will be a soft close hinge, if you do not want soft close; 73T3550.
Thank you. How do i tell if i need 0mm or 3mm plate?
Packard said:festal said:tjbnwi said:Packard said:tjbnwi said:The Blum hinge will be 73B3550, this will be a soft close hinge, if you do not want soft close; 73T3550.
I’d like to know that too. I have never understood the “plates” (and apparently I never needed them.)
festal said:Packard said:festal said:tjbnwi said:Packard said:tjbnwi said:The Blum hinge will be 73B3550, this will be a soft close hinge, if you do not want soft close; 73T3550.
don't know what they are either![]()
Packard said:festal said:Packard said:festal said:tjbnwi said:Packard said:tjbnwi said:The Blum hinge will be 73B3550, this will be a soft close hinge, if you do not want soft close; 73T3550.
I assumed that they were spacer plates. But I guess we will learn pretty soon.
