wptski
- Mar 7, 2016
I have a problem with a Bosch GAM270MFL which I first blamed on myself. It has a memory function that will store one value. This works fine for a simple miter. Using the compound miter function for use on crown molding. If I set/store 38 deg as the spring angle, I'm able to use it and get the proper miter/bevel angles to use. The 38 deg value is still in its memory.
Now if I shut it off/on again, I can call up that 38 deg again to use. The thing is that this time it gets erased from memory! So one would have to dial in that 38 deg value over and over again.
In the manual there is a description on how to use the memory hold function on compound miters. It describes the angle value will flash/blink and SPR(spring angle) icon will flash, none of this happens.
There is a YouTube video about using an older DAF220 and all of flashing, blinking, etc. does happen but no videos on the GAM270MFL or even GAM220MF that shows actual use.
Anyone else have one of these jewels?
