duburban said:what do you do ? why do you want the bosch? theres a lot of knowledge on here and if you tell everyone more about what your trying to do you'll get better answers.
i have the gravity rise on my table saw and after use i wouldn't buy it again if i had the choice. the gravity rise table saw and miter saw would fill my truck.
what i'd recommend is the smaller of the 2 fold up syle dewalt stands and make homemade plywood out feed fences to you desired length. the homemade wings will be 100 times more useful than any flimsy support that comes on the average stand.
jacko9 said:I should have explained that I have my miter saw mostly to cut rough stock to length until I get to my table saw. My shop space is limited so I thought having my mitersaw on wheels would help me manage space.
Stone Message said:jacko9 said:I should have explained that I have my miter saw mostly to cut rough stock to length until I get to my table saw. My shop space is limited so I thought having my mitersaw on wheels would help me manage space.
Hi Jacko
I also have limited space in my workshop and so I have put most of my machines on benches with heavy duty casters. My Kapex, bandsaw, 100mm extractor, gluing and finishing table, router table and outfeed table are all on casters. The beauty is that they can be moved around according to the job and can even be 'coralled' into a corner to create more space.
I have also made up a pair of light (but very strong) trestles that fold almost flat. They have sacrificial inserts on the top for sawing work.
Hi Jacko
Scott in San Diego said:I have the Bosch T4B and do like it for its intended purpose of mobility around my garage and out into the driveway. It is big and heavy. Weighing in at 135 lbs with a Milwaukee 12" slider installed, it is too much as a unit for me to lift in the back of my truck and take to a jobsite. However, the saw is easy to unclip from the stand.
The Bosch stand is not my choice for furniture making, but is great for my use in framing and trim work.
After four years of moderate use, the stand is still solid and stable and sets up and down in seconds. The extensions sag slightly when pulled out near their limits. But, so does the DeWalt sawhorse style stand that travels with me. I would buy the Bosch again and know its limitations.
