I've been using a new Rotex 150 with some 220 and 320 grit Brilliant sandpaper. I have tried the vacuum on a variety of settings to keep the sander from being sucked down onto the surface. My major issue is that I'm burning through sandpaper at a very fast rate. A single pass on a 12"x96" sheet of plywood removes a significant amount of grit from the paper. In other words, a new sheet has a certain roughness and after 1 pass the sandpaper feels significantly smoother (and it doesn't cut as aggressively). I am using the Rotex on the lowest speed setting and the vacuum at about 50% power. Does the brilliant paper "break in" and settle into it's final grit or is something wrong with my equipment or methods? There is dust loaded on the paper and on the work surface when I'm done a single pass. My garage is about 40-50 degrees but I can't imagine that having an effect on sandpaper.
Any suggestions about what's happening with my sandpaper (or proper speed and vacuum settings) would be appreciated. Thanks!
