iamnothim
- Feb 5, 2014
The planets have not aligned such that I can complete the three lower garage cabinets. Instead….
I have decided to use a couple left over 3/4” pre-finished maple sheets to make a set of speakers. This will be the build thread.
I have selected a design from Bob Brines. Specifically the M10-A10 Mass-Loaded Transmission Line speakers. $25. They use a single Markaudio Alpair 10M driver. $110 each. NOTE: I removed all the dimensions from Bob's document to protect his property.
I will select some veneers from Certainly Wood and have a PSA (peel-n-stick) backing applied from Superior Veneer. I’ll probably go with a two-tone look to match the amp I built. Similar to the illustration except the sides will be tiger maple and the face and top will be a dark species. Maybe dark cherry or a very dark walnut. I do not like brown walnut.
Since I hate edge banding, I will probably sister an inch deep piece of 4/4 hardwood to the plywood edge using dominos. This should make the recessed face come off much better than an edge band. Then again, I may chicken out and build a flush box and cover with only one species of veneer. Below is a picture of a friend's Linn subwoofer that I recovered with cherry PSA Veneer.
I’m thinking I’ll start working through the cut sheet tomorrow. Stay tuned.
Luke
[attachimg=2]
[attachimg=3]
[attachimg=4]
[attachimg=5]
Luke
[attachimg=2]
[attachimg=3]
[attachimg=4]
[attachimg=5]
