Broken Fingers
Birdhunter
A friend broke 2 fingers on his right hand using a drill. The friend was drilling through 2 layers of stainless steel each about 1/4” thick.
The drill had a side handle. The bit stuck in the metal, the drill side handle loosened from the drill, and the drill whipped around and struck the fingers breaking them.
Ouch.
Years ago I was snaking out a drain with a rented electrical snake.  The drain was below ground surface so I was on my hands and knees jamming that snake in while wearing a pair of work gloves because of burrs.  My wife had her foot on the cut-off switch pedal.  Although the snake was turning slow, it grabbed my glove and started wrapping my arm around it.  My wife let up on the cut-off switch but it did not stop.  I started working my body into the hole to allow my arm to wrap around more (Lots of torque on these puppies).  My wife saved me by thinking fast and unplugging the machine.  I did not know my arm/hand would wrap that far around.  She had to go get scissors and slit each finger of the glove so I could work my hand out.  I was raised on a farm, and am well aware of pinch points and  revolving parts.  I could not have gone another quarter turn, and was amazed I had no broken bones.
The snake went back to the rental place, I told them of the problem and to please check it because I was just lucky, and did not want someone else to get hurt.  I then got out my shovel and just dug up the line.
I used to operate radial drills at Caterpillar.  The other shift had set up a job and I started running it.  The entire fixture broke loose and started spinning.  (1.5-2" thick steel fixture).  Only thing that saved me was a piece of plywood that I had set up to control splashing cutting fluid hit me and shoved me out of the way.  First shift had the fixture tight, but had it so the fixtured twisted out of the clamps instead of into the clamps.  Never made the mistake of trusting someone else's work again.
I was using an SDS drill to drill into a concrete floor near to a wall.  The drill bit stuck and my hand, which was holding the side grip, was driven into the wall.  Power tools are dangerous.
I used to regularly install S/S handrails and guide posts (literally hundreds) using a Hilti TE 72, 2" holes.  I would have black and blue shins from bracing the drill handle against my shins to keep it from grabbing.  When I  tore both achilles reffing soccer the rehab guy wondered what I did to have so many scars on my shins.
Fingers and toes break very easily.
I am on the hunt for a new pair of "shop shoes" made of leather with toe protection, but preferably not steel toe. My last Redwings lasted many years but are completely worn out.
My dad was a scientist/engineer/professor working at the Oakridge nuclear facility one summer. He was required to wear steel toe boots. One day, he was working on a device that incorporated a very powerful electrical magnet. It was switched on, his boots (with his feet laced in them) were yanked into the magnet and he ended up on his butt. Nothing but his pride hurt.
I’ve worked in heavy construction for over 25 years. My favourite safety share is still the guy in Auckland who broke his toe pulling on his safety boots 10 years ago….,[emoji849]
