Building legs for a top-heavy coffee table
paulhuse
I could use some advice. I'm trying to build legs for a coffee table project that has a heavy slab of butcher-block as a top.
The top is two inches thick butcher-block and roughly 22x34" in size. I've not weighed it, but alas, it's not a feather-weight. I will be adding a skirt underneath the top and four legs at the corners. I've considered a few different types of construction for the legs and their attachment. That's where I could use help.
I want to make sure that I'm building this so it won't fall apart. AND I don't have a domino jointer and don't even say I should buy one (I hope to someday) unless you have a $1250 USD check with my name on it.
The customer wants walnut for the legs, skirt and edging. I've considered building a box leg and attaching it to slightly recessed skirts--similar to that of the image.
So... how would you recommend attaching the legs to the top/skirt? What kind of construction would you use for the legs and how big should they be to have enough stability for the project?
I've enclosed a photo of a similar construction I'm considering for the attachment.
The top will weigh ~40 pounds assuming it's hard maple. Depending on what means you have available you, you can use mortise and tenon, a corner brace or even pocket screws. If I was building it I might make the apron/skirt a little deeper where it meets the legs to give myself more contact area and prevent any chance of racking.  (arch the apron if it looks too heavy)
http://www.tablelegs.com/Parts/CornerBraces.aspx
Good luck, looks like and interesting project.
Apron/skirt... It's something a women wears, not me. :)
Thanks for the note. Yes, I think the corner braces are the way to go. I really wanted to have the option for the legs to be removed and/or tightened... which is what the corner braces provide. But I fear I need to lock the legs to the aprons with T&G and glue to support the weight.
Thanks, again!
