Hi.
I'm in the process of building a permanent workstation out of two MFT/3.'
Here is what I want:
- Small footprint but efficient workstation
- Full MFT functionality for clamping, Qwas-dogging square glue-ups, etc
- Solid/Sturdy
- Lots of drawers
- Adjustable in 3 axes to square and level the two tables (images below shows aluminum mounting brackets to build)
- CMS saw station in the middle with detatchable Incra fences on both sides (probably mounted with some kind of dogs)
- CMS pivots so I can get a clean table area in the middle
- CMS also slides so I can push it backwards when I need to stand in between the tables (for routing etc)
- CMS slide function locks in 96mm increments to match MFT holes for exact fence placement.
- Incra LS station on one of the tables (detachable)
- TS-55 saw station on the other table
- Good dust controol with boom arm and both 27mm and 36mm hose
- Shelf rack on front to hold standing work pieces on the side on any height
- List is growing for each day.. This will be really fun to build.
The base will be welded out of 50x100x3mm steel bars.
The sliding funtion for the CMS will be a heavy duty guide rail
- Solid/Sturdy
- Lots of drawers
