dlu
I'm visiting family in the Netherlands which, naturally, means that thoughts of entertainment naturally turn to remodeling...
Specifically, their apartment has nice high ceilings except in the entry hall where the ceiling has been dropped. I think this was done to hide a structural beam that passes through the hall. The building was built not long after the war and the walls are real plaster. The material used to drop the ceiling is super interesting. It's a plastic extrusion that you run around the perimeter of the room, with neat little covers for the corners. Kind of like a surface mount wiring system. Then a sheet of vinyl (I think) is stretched between the extrusions and held in with strips of masonite. A miracle is performed at the final edge and it really looks quite nice. But doing any work above it requires undoing the miracle (and then redoing it) and doing things like hanging lights is quite a challenge.
Anyway, we're thinking it would be fun to pull that down and run some picture mold around where the extrusion used to run. That part seems pretty straight forward. The beam however is in kind of funky shape and has a couple of runs of conduit on the face. So I was thinking that we could fur out the face of the beam and then cover it with sheet rock. But... My efforts to find sheet rock on the Praxis (https://praxis.nl) website have been less than successful.
So, I'm wondering. How would you properly tackle this job in the Netherlands? Is there a product like sheet rock here with a different name?
