DelawareRick
- Oct 24, 2016
I'm going to try my hand at making a set of Sysports using the Sys-AZ drawers, but also would like to make the sysport cabinets according to the 32mm cabinetry spec. The idea is to make the boxes "universal", so that they can fit both the Sys-AZ drawers, and DIY cabinet drawers using the 32mm system.
I'm wondering if anyone else has done this, and if there are any particular issues I should be aware of. Basically, I'll follow the instructions as outlined for Sys-AZ drawars, but then follow up with holes drilled per the 32mm spec (5mm holes, 32 apart, 37 back, etc) Any insights, opinions, etc are appreciated.
Second, I'm trying to get my head around where the first/lowest hole should be for the 32mm part of this. I want to build these like typical cabinets, with the bottom horizontal piece sitting between the two vertical side pieces. Does my first hole need to be 32mm up from that? (32mm + materical thickness?) If the first hole isn't going to be at 32mm, then I won't be able to use the end stops on the LR32, correct?
In case it's not obvious already, I've never done cabinets before so I'm very "green".
