Built In Wall Unit : In Progress
Hello,
This is a photo of a built in that I have in progress.  The room is 12 feet wide, and the cabinets go wall to wall.  I am using red oak with nice wide 2 3/4 inch stiles and rails.  This is an all Domino construction project.  I just counted 104 dominos to date, all drilled perfectly.
The centre unit is about 1 inch proud of the two side units.  I built the two side units, and then built the faceframe of the centre unit to fit perfectly.  There will be inset doors on the seven bottom sections, and three glass inset doors in the centre section.  The centre section will have lights.
I have been sanding my face frames with the R090, RTS 400 and the DX93 for the 3/4 inch tops and bottoms.  I think the DX93 is a great little tool.
I am going to finish with General Finishes Java Gel, and spray GF enduro var.  I hope you like it, and I will post a photo when finished.
Brian
