I have made cabinets and tables in the past and made buttons to secure the top typically 5x30mm but the dresser I just made is likely to be lifted and moved by the top. I used 3/4” oak and will make buttons with the same dimensional wood. I’d like to use 8x40mm dominos and am wondering if I can get by with the settings 15mm into the frame and 25mm into the buttons. It appears as though they would work without punching through the same and not sure if I even need glue as it is such a tight fit. Logic tells me to use the 12mmx25 but am wondering what the experts use.
