Crazyraceguy
- Oct 16, 2015
I have been playing around with leg shapes/designs in my head for a while now. The idea that struck me during the square taper to octagon seems like it would not work for this one. The legs are too short for it to flow right, something else was needed, so I went for another experiment. The taper is on the outside of the legs and inverted. This gives a somewhat bell-bottom foot look. At least that's how I imagined it? I wasn't sure how it would look...and took a chance.
The disadvantage of this is that the thinness at the top doesn't leave much room for joinery. I put a couple of 8mm Dominos in the aprons but had to miter them to not interfere with the adjacent side. I resolved the glue contact area issue with some diagonal blocks on the inside. It's probably still not the strongest thing, but it's for my own use, rather short, and the top is only 22" square. For a coffee cup, TV remote and phone charger, it should be fine.
It's all made from more of that same reclaimed wood from before. Red Oak on the legs, this time with lacquer to give some color, and I just don't know about the top? It is very fine grained, soft, light weight, and has some spalting too. I used the same water-based Polycrylic as before, trying to keep from changing the color. Both still need at least one more coat and some buttons to hold the top on, but it's close. Not bad for a few extra minutes each day this week.
