Buying of1400, what accessories/fence?
I would definitely add on the edge guide.  To support expanded capacity routing off the edge with the fence, I also bought some extra long 8mm rods from McMaster Carr.
I find the table widener to be helpful as well, though if I were getting the router today, I would probably make my own version since I now have that capacity.  I forget, but you may have to purchase the extra large chip catcher separately that goes with the table widener.
The guide stops too if you want to do rail guided routing.
I second what Edward said about the table widener.  I felt that was quite important and added to stability when I was using the 1400.  I think the chip catcher came with the TW, but I bought mine many years ago and maybe FT has changed that offering now.
I would also like to ask that I read somewhere the 36mm hose does a noticeably better job with dust/chip collection?? Has this been your experience?
[member=72021]Thompmd[/member] Yes, the larger hose makes a substantial difference with this router, though I will sometimes still use the 27mm if I'm in the middle of something and too lazy to switch.
As always, thank you all . For example , I keep a Short (5’)Dedicated piece of 36mm Hose hooked to my Kapex so it takes just a second to swap. Once I feel comfortable with a length/location of the Router I’ll do something similar with a dedicated 36mm hose.
Most All of these come from you guys and it’s much appreciated.
I found the 36mm hose too stiff and unwieldy to use with the OF1400 and went back to the smaller hose. Assuming that for bigger cuts you are sneaking up using 2-3 smaller cuts I found the smaller hose is fine for dust extraction.
Interesting point, being new how often do you make more than one pass ? I’ve only made 1 and had no trouble?
I’ve only used on hardwood so far, mostly Walnut.
I’ve used my Bosch 1617 and new 1/2” Freud bits so they’re sharp.
