Just received the Panasonic Revolithium models yesterday (impact + drill) and the first impressions are very good, not too much testing yet except from driving a handful of 1/4"x4" (6x100mm) screws into solid wood.
When using the impact at it's max setting (2300rpm), the screw is flush with the material within 2seconds(!) - AND the rattling of the impact mechanism only engages for the last 15-20mm (~1/2 - 3/4") - it's also a unfamiliar feeling, as so little of the torque is transferred to the hand.. makes you look three times at what just happened, and 'is it really in?'
A few weeks ago I used my C12 to drive the same screws into ceiling joists for a day, it ofcourse did the job really well, but my wrist remembered it for a few days. Had to give the C12 a few breaks during this because of the overheat protection beeping, apart from this it performs much better than it should for a 12v drill
Not sure if this is the right place for a review of Panasonic tools, I'll just say they are not Swiss Made Fescool precision engineering, but seems extremely well built and solid for being a 'Made in China' tool.
Extremely light and the handles are perfect (for me), the drill runs circles around my aging Hilti 15,6V/3Ah cordless both in torque, speed and ergonomy + it's half the weight..
Panasonic drill is confirmed non-brushless btw. but it's no problem.
Both unit has enough intelligence to protect themself(overheat/overload as the C12) and the battery against draining below safe levels for a li-ion + ofcourse electronics to keep the rpm steady regardless of torque.
The separately operated white led 'worklight' is also a nice feature, will auto shutoff if unit hasnt been used for 5minutes, placement seemed strange (at top of the battery/shoe) but it's perfectly alligned in the center of the action when using a drillbit or bit extender
Included charger can charge batteries from older Panasonic's, as well as Li-ion up to 28,8v(the sds stormtrooper edition above)
Seems promising, only faults I've found other are mentioning are the handles - to small for large hands in gloves, and a fella who had to change brushes in the drill 2 times in less than a year(bought just after release).
Thanks for reading this far, I'll shutup now and join the topic of this site again
Have a nice weekend folx!
