Papajoe
- Mar 19, 2011
I have recently decided to build 7 houses, and i have been researching how to build the cabinets. You tube has several festool cabinet videos, but most of which require a table saw. My limited understanding was that a ts55/75 and multifunction table should do the job accurate and in competitive time frames.
referance 1. you tube - How To Make Plywood Boxes • 3 of 64 • Woodworking project for
referance 2. you tube - The Basics of Cabinet Making Part 1 . by joeusco1960
both use a ts55, to rip the sheet long ways, then goto a table saw to re-rip "accurately" the width, and then back to the ts55 to cut the side cuts?
i must be missing something, but just to use the festal and long guide to "rough cut" before a precise cut on a table saw seems a wasted step? if the festal can't cut the first cut accurately (skipping the table saw), and if the objective is only to get 1/2 of sheet of plywood for easier handling, grap any circular saw and a 2x4; plus or minus 1/2 inch is no problem.
i wonder if festool has a table saw in the cabinet making class?
thanks for any insight on the subject
joseph
joseph
