Calibrating Domino 500 pins
ear3
New York, NY
I just noticed that there is a small offset in the joint when I locate off the edge of the board with the pin using the narrow setting on both mortises.  I hadn't noticed before, probably because I usually use the wider mortise setting.
I know there's a procedure for calibrating the pins (the plastic ones that fold in and out) in the supplemental manual, but when I go to the PDF through the Festool page, none of the included pictures are visible.  I'd prefer if possible to do the calibration procedure with visuals.  Anyone have a good copy of the manual they could direct me to?  Thanks.
