Can I buy boom arm hose?
Tim2178
Hello all!
Does anyone know if I can buy a short piece of 50mm hose for a boom arm I am trying to rig up? I just got a CT 26 and would love to get the boom arm but won't be able to spend the money on it yet.  Also, not sure if I will need a short 15 amp cord also.
I hope someone can lend a hand.
Not sure if it's offered separately in the US as an assembled item, but I'm sure you could get the connectors and a length of the relevant diameter hose as spares through your usual dealer.
Can I order somewhere online? My local dealer has to just order everything too.  Not a huge inventory.
I'm sure Bob Marino can help you out.  I purchased a custom hose from him last year when I was trying to get a reducer for 36mm hose.  His price was extremely fair.
Here's the EKAT (Festool's parts) page for the parts for the Boom Arm:
http://ekat.festool.com/EKAT_USA/jsp/main.jsp?doAction=start&partLang=en&docuLang=en&locale=en_EN&viewerType=6&k_vari_top=492762&k_ver_top=&verticalLayout=1&HOOK_URL=&currency=USD&filter_F_Typ1=on&filterValues_F_Typ1=US&currencyKey=US
The 1.5m length of D50 AS hose is made up of the hose and two end fittings.  And, you will need a hose connector to connect this hose to your current hose.
So, you will need:
One (1)  D50 x 1.5m AS hose -- part number 452386 (D50 MW-AS) -- item 4 on the parts list
Two (2)  D50 Rotating Hose Seleves -- part number 452896 (D50 DAG-AS) -- items 3 on the parts list
One (1)  Hose Connector -- part number 493047 (D50/D50 VM-AS) -- item 1 on the parts list
There is also the additional power cord that comes with the Boom Arm:
One (1) 1.5m Extension Cord -- part number 492757 -- but at $63.02, you can get your own extension cord for far less.
The Festool EKAT system is found by selecting Support from the FestoolUSA site, and then selecting Electric Parts System under the Assistance column.
So, you will need:
1.5mm hose and 2 end fittings.  For my application,it's going to take the place the of the DD hose running from the cyclone outlet to the Festool CT inlet. Looks like just the 2 50mm sleeves will do me.  Thanks for the detailed info though [cool]
So, you will need:
Thanks Corwin.  Will the hose that comes with the ct22 be long enough to run on the boom.  I can make my boom a little shorter.  Can anyone tell me the height of the boom from floor to boom top?
In inches, I believe it's about 82 1/2". Someone who sells them, or actually has one can verify that for you. [cool]
Thank you.  Sounds like you need to talk to my brother.  He has been a roofer for 20 yrs!haha
