Hey guys,
When it comes to feed rates and spindle speeds you can learn a lot at Onsruds website. The general rule is that you want to take as big a chip as possible (thus reducing heat). The trick of course is to get a good cut quality along the way. As a professional woodworker for the last 15 years I an tell you that most people (including myself until I studied the info about cutters at Onsrud) feed WAY to slowly. It's especially important on CNC machinery.
We make cabinets for Hewescraft aluminum boats. Using a two fluted bit and running the spindle at 22,000 rpms (full speed) we could make about 4 sets of cabinets before the bit was insanely dull. After reading about it, we switched to a single fluted bit and turned down the spindle speed to 6,000 rpm and kept the same feed rate on the CNC. The result, our cutters last 20 TIMES as long before they get dull. Now we only change the bit every few months instead of every week.
At first I was skeptical about it, but I was dead wrong. There are all kinds of benefits including the router not being nearly as loud running at a slower rpm. I'm no expert when it comes to aluminum routing but I remeber seeing information about it on the C.R. Onsrud wesite.
Good luck
