I'm making a headboard for a bed and the requested "pine country" style involves some frame and panel sections. The part I'm concerned with has 4 panels across that are 24" high x 16" wide. They are to be set into 1/2" deep grooves in 3" wide, 1 1/4" thick frames. The panels are 3/4" thick knotty pine ply (good quality from Nashville plywood). I door a fair number of cabinet doors with a ply panel which I would glue in but I'm concerned with the size of these. Should I be? Can I use that method here? If not, I'll probably make the grooves a bit deeper since I want this to be solid.
Anyone have any experience with this kind of thing?
