Jonathanmarshall said:When I was considering upgrading to the new 8ah battery, I realized it's always a good idea to double-check the compatibility with your specific device or system. You can do this by referring to the manufacturer's guidelines or reaching out to their customer support team.
slavi.yordanov said:Will that 8ah battery ever make it to the US market?
slavi.yordanov said:Well, the crazy (or stupid) part is that it won’t even work on the CTC MINI/MIDI. Cordless vacuum is one of the most demanding tools, and to limit which batteries work on such tool..I still get mad every time I pull the CTC Sys out. On top of that, if you don’t hit the power button, batteries get drained in stand by.
Meanwhile the Milwaukee runs forever on a single 12Ah battery.
Not apples to apples, one is an 18v shop vac, the other a 36v hepa extractor. Different tools for different jobs. Imho
Yes it does, for about 5 minutes, then it starts loosing suction because the batteries are half drained.Coen said:The Festool sucks harder so of course it's runtime is worse.
The Bosch only fits the 12Ah without lid
Are you talking from personal experience with those vacuums or just by looking at specs? I don’t ever use the CTC on high, simply because it’s unusable. Try doing a 20 minute continuous clean-up with it. That’s one task where you need maximum suction, and the CTC totally sucks, in a bad way. Nobody is asking for hours of runtime, but if you look atmino said:slavi.yordanov said:Well, the crazy (or stupid) part is that it won’t even work on the CTC MINI/MIDI. Cordless vacuum is one of the most demanding tools, and to limit which batteries work on such tool..I still get mad every time I pull the CTC Sys out. On top of that, if you don’t hit the power button, batteries get drained in stand by.
You can have two of the three:
- power
- weight/size
- runtime
Festool has both "high end" option where power is good (and so can be the filtration):
- the CTC SYS series are small and powerful (but have low runtime), they are ALONE on the market with that combination of size/power.
- the CTC Mini/Mid series are powerful and have a good runtime (but are relatively heavy and big), these form the high end of reasonably compact cordless vacs.
Then there is the "size/weight is no object" where the CT 26 + POWERSTATION runs supreme. Basically, once the 8 Ah packs are available, Festool will have as complete a portfolio as it gets.
The only product not offered will never be offered - the small and weak one. There is no point in that either. There are plenthora weak vacs on the market covering that use case from almost every maker. So if bad extraction is something you are fine with, do not look at Festool. And I mean it.
They are not after that market. Not since 20+ years ago.
Also, if you want better runtime, run the CTC SYS at min power. For most tasks that is very much adequate - it compares to most vacs of the size at full tilt but with way better filtration.
Also, you possibly misread somewhere, the CTC Mini/Midi series support the 8 Ah packs. Once they will be available, of course.
Shortly:slavi.yordanov said:It’s hard to convince me how making a high demanding cordless tool compatible only with small batteries make any sense. Imagine having a V8 sports car with a 10-gallon gas tank.
https://www.festoolownersgroup.com/...idi-i-thoughts/msg702972/?topicseen#msg702972Bencan said:Is anybody actually running a ctc midi? I’d like to get one to try it out potentially but I’m sort of assuming you’ll need to least 4 5ah batteries for this to function reasonably well? Be curious to hear people’s experience
Thanks for thiswoodbutcherbower said:https://www.festoolownersgroup.com/...idi-i-thoughts/msg702972/?topicseen#msg702972Bencan said:Is anybody actually running a ctc midi? I’d like to get one to try it out potentially but I’m sort of assuming you’ll need to least 4 5ah batteries for this to function reasonably well? Be curious to hear people’s experience
16 minutes run time on a full charge .......
