Can you recommend a few must have Carvex jigsaw blades?
festivus
I keep getting caught short not having the right blade for my cordless carvex.
Yesterday it was a ceramic tile cutting bit - so that's on my list. I had to go to B&Q and get a blade - they only had their own brand which proved awful. (What speed should you run a ceramic cutting blade? Tried both fast and slow - and managed to crack two tiles (albeit B&Q's cheapest!)
Festool don't do a set - but if they did - what should be in it for:
General work, including 18mm veneered MDF,
Do they not do the set in Europe?  Here it's M0122:
http://festoolusa.com/power-tool-ac...blades/35-piece-jigsaw-blade-assortment-m0122
I did not know they sold packs this big. I feel like that kit is super cheap as I bought a few separate packs of 5 like 16 or 19 bucks.
Thanks - that kit's not available in the UK. But does give a good reference for some blades to have to hand.
With a bit of research I've ordered this lot in case useful to anyone. In my opinion, these should cover most eventualities (wood, sheet metal and tiles).
It took me a while to work out the difference between the FS, FSG (these are the thicker, Carvex specific blades - with different tooth profiles only) and the "no suffix" (standard blades). The US Festool link is useful.
Festool Jigsaw blade HS 60/1,2 BI/5
Code: 486556
Festool Jigsaw blade R 54 G Riff
Code: 486562
Festool Jigsaw blade S 75/4 FSG 5X
Code: 499476
Festool Jigsaw blade S 145/4 FSG 5X
Code: 499478
Festool Jigsaw blade S 50/1,4 K/5
Code: 486564
