Carvex 420 won't take S75/4 blade
endgrain
I was cutting some 8/4 hardwood today and when it came time to do the rip portion, I wanted to change to a more aggressive blade --> S75/4 FSG. I've alway had trouble using this particular blade in my carvex and for the longest time I thought the problem was on my end but after near fifteen minutes trying to get the shank to lock into the carvex, I ended up going to the previous blade.
Is the S75/4 FSG not compatible with the Carvex 420 EBQ (maybe I missed it in the specs?) or is it something potentially wrong with my Carvex or the blade itself. I tried other festool blades as well as a bunch of bosch blades and they don't have problems locking into the collet. The main difference I see between the other blades and the S75/4 is that the '75 blade is 1.76mm thick while the other blade that works is 1.49mm thick. The "T" portion of the '75 blade is also a smidge wider (I have no way to measure).
I appreciate any insights or if I should send my tool in for warranty. Thanks.
It should fit no problem.  Have you tried to insert multiple versions of the S75/4, just to check whether the one you initially tested might be defective?
I have the same problem, although my blades will fit after fiddling for a minute or so. Pretty annoying though, so I will probably send it to Festool for repair. I don't think it was like this in the beginning, so something may have happened during use.
[member=32782]endgrain[/member]
There are older blades with "Trion" written on them. They are slightly too thick to work with the Carvex but these blades have been discontinued for a long time. All other blades should fit.
Really? That's not been my experience at all. Maybe I just got lucky, but I've never had a problem.
[attachimg=2]
Garry,
I think that it wasn't across the board that ALL of the Trion-marked blades wouldn't work, but some were problematic. That's why those blades were replaced with the newer ones marked Carvex.
* Your results may vary.  [smile]
Thanks. Mine says carvex so no luck for me.
Did you try others of the same blade model? Maybe it is that particular S 75/4 FSG. Maybe the blade is defective?
Mine works fine, maybe it's just that particular blade. Try a different 75/4 FSG blade.
I had many many issues with my new carvex about a month ago, most of which I detailed in my thread about it
http://festoolownersgroup.com/festool-tools-accessories/carvex-psb-420-ebq-reviewthoughts-(not-impressed)/
Extreme difficulty inserting the thicker gold blades was one of the issues. I had one get stuck in there and spent a long time with pliers trying to get it out. Called festool and had to leave a message (during business hours) and NEVER received a call back.
I ended up not being able to use any of the thick (yes, specifically carvex) blades in a job that I specifically bought the tool for. I'm pretty sure my saw was defective, if in no other way than the blade insertion/release mechanism machining tolerances because I returned it and got another one (barrel grip, from the stupid d-handle one) and it does *not yet* seem to have this issue, though I haven't gotten to play with it at all yet except for sticking blades in and out of it.
Long story short, you're not alone...
Festool service took care of the problem, something about the collet nut being too tight preventing the thicker **ahem** festool **ahem** blade from seating. All is well now  [smile].
Hey OP - I'm having the same problem.  Brand new 420 EBQ and I tried for ages to insert the BLADE THAT CAME WITH IT and couldn't.  It's the same blade you couldn't get in there.  The smaller black blade went in fine but my earlier struggles jacked up the collet so badly that it broke the ejector mechanism.  I'm literally sending the thing off to service after 1 cut of 1.5".  Seriously?  Pretty frustrating for high end stuff not to work with its own accessories.
Glad I found this thread because I thought I was crazy not to be able to fit the gold saw blade on day 1 of having the Carvex.  [eek]
I'm having the self same problem.  Ive scraped off the gold paint but the blade still won't go in. Ive measured the thickness and as far as I can see its almost 0.5 mm thicker than the black blades and the lugs seem a fraction too proud also.  The blades supplied with the saw worked. Whats going on with festool?
