Today I just purchased and used the Carvex circle cutter attachment.
Firstly - what a great attachment! - I found it easy to set up, attach, and use. I followed the tips from Peter Parfitt's video and it was great. It tracked well and ended exactly where it started.
My only comment was that it was a little inaccurate in the measurement scale. I wanted to cut a hole to 28.5mm radius, and in the end it cut 28.75mm, which meant the circle was 5mm bigger in diameter than desired. I had used a pencil to mark out the cut line by tracing the mark in the centre of the guide, and when I measured that it was correct, but the cut line turned out a tiny bit too big.
Does anyone else have this experience?
I understand that there are quite a few variables at play such as the thickness and width of the blade, so in the end this is more of a comment rather than a complaint.
I also had a question - is there any way to avoid the 4mm hole in the centre of the circle? With the router, I would stick a piece on top in the centre, and have a same thickness piece at the end of the trammel.
I found this arrangement faster to setup and produced less waste and in less time than the times I have used a router and trammel arrangement. I think I will be using this method for a majority of times in the future where being super accurate is not a concern. Otherwise I will use it to cut an oversize circle and follow with the router for the final cut.
I am very happy with this purchase and do highly recommend it for those that need to cut circles, and am now considering making the parallel guides for the guide rail using another one of these. [big grin]
