Holzhacker said:Put out a useful and affordable Centrotec set and building will buy it.
So here are my suggestions.
- Scaled down useful and affordable set in a Sys 1
or even better
- Somewhat specific sets each in a mini-Sys. One mini-Sys might contain drivers, another extensions and countersinks, another wood bits, another metal bits. This makes each set easily affordable. Customers can pick which set-up they need when, can stack in a larger Sys as needed, etc. This will greatly boost sales.
Also Yes a mini-Sys would be a great stocking stuffer. ;D
Shane Holland said:So.... Given the choice, would you rather have some (probably metric version) Centrotec Set sooner or wait for a possible imperial version later?
Edit: Added a poll to make it easy to consolidate the votes.
greg mann said:If it would be faster I would take metric in half mm increments in a mini. I would never be more than a few thou off a perfect Imperial size and that is fine for almost anything.
Dan Rush said:I'm not sure I'll ever be in any danger of thinking in metric, but I have gotten used to knowing the metric drill sizes since switching to Centrotec. I'm with Greg, metric now; I can find a size close enough to work.
Dan
WarnerConstCo. said:Dan Rush said:I'm not sure I'll ever be in any danger of thinking in metric, but I have gotten used to knowing the metric drill sizes since switching to Centrotec. I'm with Greg, metric now; I can find a size close enough to work.
Dan
Yup, close enough is right. Seriously, are we going to split hairs over imperical vs. metric drill bits? I bet if we dumped a bunch of unmarked bits in a pile no one would no the difference between metric and imperial sizes.
This is for Shane- Speaking for myself and I think a few others here, we are tool whores, make all the acessories available and I will buy them. I mean I bought the 35.00 belt clip thing. It's like 8 bucks for the Husky one but, that would have been sac-religious!! You guys could/should make a killing off the little silly things. I know I always buy at least one thing when I go to Woodcraft, wether it be a clamp, backing pad, splinter strips (tell Woodcraft that you make clear ones now, they dont believe me).
And we have been trying for square (Roberson) drives for over 5 years. Christian seemed seriopus back then about supplying Robertson drives and I understand that he tried but I have come to beieve that it won't ever happen.greg mann said:If it would be faster I would take metric in half mm increments in a mini. I would never be more than a few thou off a perfect Imperial size and that is fine for almost anything. Getting Festool to make the Centrotec drills in Imperial will be as hard as getting square drives.
