Crazyraceguy
- Oct 16, 2015
[member=44099]Cheese[/member] I was referring to the machine itself, not the just the cutters.
I am completely on-board with the idea that the material matters. I have worn/dulled a few of them. I assume that the adhesive in plywood is at least a little rough on them. I occasionally have to cut them into the face of plastic laminate pieces too, and I'm sure that is not good for them.
I have also broken one or two by hitting an 18ga brad inside an assembled unit. [unsure] Knocked the carbide tip right off of one of them [scared]
In the usual White Oak, Maple, Cherry, and Poplar that I come across most, you can hardly tell they are used. They just keep going. I keep a 6mm isolated, just for sheet goods.
